VR scale feels off after Enscape 2.5
Hi, I have been using Enscape for a while and I loving it. After 2.5 I noticed that the scale inside the VR fela bit off.
For example the celling is at 2.6m in the model but in the VR it feels lower. I measure with a tape and its about 2.4m.
Anyone had this issue? ;( ;( ;( ;( ;( ;(
FYI in seated mode the scale feels right
Hello @akaflux_1 ,
room scale VR is always a bit tricky, it needs to be setup properly to work as a expected. Nevertheless the 2.5 had a bug where the spectator height was about 10cm off from the set value. You can try the latest preview and see if the issue was fixed.
