VR Scene no Animtion contained
I have a cinema 4d scene where some elements are animated/baked into keyframes which I want to sent to another artist using 3ds Max. However the animation doesn’t come through. I also tested it in cinema by reimporting the file but the obejcts won’t animated at all. Is there something to look out for or change to make the animation to export?
Thanks for your help.
Best
Hello @pascal_frst ,
Have you set the correct frame range of your animation prior to exporting the vrscene file? Upon testing on my end the animation is properly exported and imported into 3ds Max or back into Cinema4D. Please make sure that you have set the correct frame range in the Output section in the render settings, then export the vrscene and let me know if you still experience this issue. Thank you.
Hey @aleksandar.kasabov
thanks so much. I thnk that did the trick. I didn’t know that the render range was the key for setting up the exported range. If there is anything else I will let you know.
Best
Pascal
