VR Standalone Executable
So I get the basics on creating a standalone executable. However, to create a standalone file that uses VR, do I have to have a VR headset plugged in? Or do I just need to enable it in the Enscape tab? I’m working in Revit, if this makes any difference at all.
Thanks!
Hey @arkisak , in the past you would have had to activate the VR headset via the dedicated button prior to exporting a VR-enabled standalone file. Now a days you can just open the dedicated standalone menu via the little flap to the left and simply enable Virtual Reality once required:
I hope this helps. Let me know if there is anything else I can assist you with!
This helps a lot! Thank you very much!!
Yeah, that panel, enscape is full of surprices :wink:
