Hello
Say you have a bitmap used several times in scene materials - some as is, and others have a colour correction applied. Does Vantage load just the one bitmap in memory, or would it load a colour tinted version of the bitmap as a seperate item in VRAM?
Such textures are part of a shading graph and the bitmap exists only once in memory. The shading graph (color modifications) is evaluated at render time.
The textures are also mipmapped and only the necessary level is loaded on the GPU (unless “dynamic textures” is disabled). If you’re worried about texture memory usage you can check it in the new File->Texture Stats window.
That’s good to know - thank you Nikola
