Vray 1.5 Rhino 5 - Small to Large Renderings
I think at bigger render size the ground is to much subdivided into micropolygons (maybe you can’t see it, because the displacement is much to fine) and the strong RAM usage is causing the slow down, like Svetlozar wrote.
Is you light cache calculation not extreme slow? The LC pass needed several minutes at 32 cores here. Also during the LC pass the RAM usage is extreme growing up to 14GB (image output 1500x..). If I use the GI cache trick and use the cached GI, than the RAM usage is 11.5GB.
I think you could do two things - find the lowest displacements settings for saving RAM and against RAM swapping + speed up the GI calculation by LC caching without displacement.
I looked at an old 1.05 project from me there I used displacement for grass too. At this project I was fighting with the RAM and end up with displacement edge lenght 3 and 20 max subdivs + LC cache trick. So I got a 3000 pixel image rendered within one hour at my old machine, if I remember me right.
Hello Micha,
I am using vrlmap’s for both the Irradiance Map and Light Cache calculations so this essentially eliminates the large amount of time you are referring to. I am not convinced that the long render time has anything to do with displacement as the render only freezes when it gets to the “glass” portions of the scene I am trying to render.
Out of curiosity when you rendered the image how long did it take for the whole scene to render? If you did not render the whole scene then you probably don’t know what I am talking about. I don’t have another computer to test this myself so I would really appreciate it if you could tell me if the render does freeze when it starts rendering the “glass” and how long the whole scene takes time wise for the 3300 x 2700 pixel image.
Timmy if you want to put your file somewhere I can get it and try it on my side.May be we could find a solution
Renee
But if you precalculate the LC + IM cache, did you set the displacement at amount 0? My problem with your scene is, that the LC needes a long time and a lot of RAM, if displacement is used. Disable the displacement for the LC helps me a lot. Try it. And first try to render your scene at different resolutions with displacement amount 0. Are the large renderings really so slow? Maybe anything works like expected without displacement …
RAM usage - I tried lower displacement settings and the RAM usage was halved.
But there is a problem with your setup - you disabled the max reflection/refraction depth, but before you set it at 5. Your glas is set at -1, this means the global options is used. If I understand right, set the depth at 5 and disable it means that 5 is used for all materials except material where not -1 is set. If you would enable the global options, the depth 5 is used for all materials. Attached a quote from the developer. So your glass was slow calculated by to much interreflections.
Your glass was so dark and don’t understand why. I created a new one, like I wrote above (reflection + black diffuse ..) disabled reflection at backside and disable cast shadow - now I get light inside and reflections.
Sidenote: you can enable “low thread priority”, it doesn’t cost time, but you can much better parallel use your machine. :wink:
My attached rendering shows the time (for the rendering with displacement) without precaculation the GI, but it doesn’t need to much time. The other times are full times.
Quote from Joe about reflection depth usage:
“The Global Max Depth was made to override all the max depth on the materials. If you want to control the max depth per material, then you have to disable the Global Max depth and use the materials option.
In V-Ray for Rhino we have -1 as the default max depth per materials, that means that for that material you will use whatever the max depth value you have on the global max depth. For example if you have Global Max depth to 5, all your material will use 5 max depth no matter if the Global max depth is enable or disable. So in your example, you can set the Global max depth to 1, then disable it. That mean that all the material with -1 will use that global max depth of 1. Then you can change the glass material max depth from -1 to 2. But if you enable the global max depth you will override all the materials max depth.
The trick is enable the Global max depth, jut to be able to change the value to 1, then disable it to avoid that the global max depth override the material max depth. Then just change the max depth of the materials that you want to be more than 1.”
Here a test with new glass, low displacement settings and reflection depth 1.
Hello Micha,
Thanks for rendering that sending me those settings. After I sent you my scene I had tried using the “fake” glass material you describe. It did not seem to speed things up at all.
Could you tell me what size you did those renderings at? That will explain to me if it is a displacement issue or not? My computer has no problems rendering the smaller images, it’s the larger one’s that seem to have issues (ie. 3300 x 2459 pixels).
M test was at 1500x1159 … I didn’t try a bigger rendering since I think it’s wasted time so long the RAM usage is so high that swapping starts.
I don’t understand why you not talk about the RAM usage at your machine. How much RAM you have installed and how much RAM is using your Rhino? Like I wrote, the displacement tessellation is dependent from the view, from the output size. A bigger image cause finer visible displacement details that cause a higher RAM usage that cause harddisk swapping that cause longer render times.
OK, I started a 3300x… test. Like I sayed, your setup is to much RAM hungry and the LC is slow, because the displacement. After some minutes I have LC pass 5% only and 14GB RAM usage, increasing with every minute. I stopped the test at LC 20% and 18GB RAM usage. That’s no practicable way for rendering this scene.
Hello Tim,
I think I found a solution for this issue.
I have optimized your scene a bit - and I managed to render 3k resolution for 1h and 17min with 8GB RAM usage.
The main optimizations are on the materials(reflection layer) and displacement settings.
I have found that the main reason for the slowdown is the glass objects in your scene. By default in Standard Material options, reflection on the back side is turned on - unfortunately this increase rendering time a lot, and it is recommended to turn it off because it doesn’t contribute to the quality too much , but the render-times becomes quite slow. So I went through all of your materials with reflection layers and I turned off this option.
The next thing that I did is to set limit for reflection/refraction/transparency depth - since you have a lot of these objects in the scene it is necessary to set some limits otherwise Vray could spend a lot of time calculating properties which doesn’t influence the quality of the render , but affects the render-time.
In Global switches rollout I entered reflection/refraction depth = 4 , and transparency depth = 25.
Next change is connected with the RAM usage - by default displacement is set to 256 subdivisions which is too much , for small resolutions this is not an issue but for larger resolution Vray subdivides the geometry too much and this leads to using a lot of RAM - and when all available RAM is occupied it starts to swap memory and the render becomes very slow.
So I have changed subdivisions to 4 and edge length to 5 - and with these settings I got only 8GB usage during 3k rendering.
I think that everything will be fine now - but if you still have any troubles with the rendering please inform us as soon as possible.
