I’m still trying to pin this down but any time I do a large rendering at these resolutions vray crashes. It’s a very simple scene. I can render at 2700px wide just fine. But when I set the resolution to 2800px wide (and higher), I get:
error:unhandled exception: Rendering frame Last marker is at .\src\vrayrenderer.cpp line 2327: Preparing direct light manager
I have a sunlight in the file but even deleting the light (the only light in the scene) will throw this error up. Also, GI is off and it still does it. It crashes 3dsmax completely. Thanks for the help if you can fix this. I need to be able to do 3000px renderings. It doesn’t matter what I set the “dynamic memory limit” to in vray options, it doesn’t change the situation.
System: WinXP32 with 3GB switch enabled, 4GB ram (ram is only 1.2GB used total), 3dsmax2011, vray 1.5 SP5
