VRay 1.5sp5 Physical Cam Bug
Hi Vlado,
If you select VRay Physical Cam and click to create a camera in any
veiwport without dragging the target max crashes.
This ONLY happens with max 2009 (both 32 and 64). I have tested on
2010 and 2011 and this does not happen.
I’ve ran into this as well.
V Miller
Thanks for the pointer; I’ve noted this and we’ll fix it.
Max 2008 x64 either…
sometimes in max9 x64, I get a similar problem. I go into top view and try to create a Vray Phys Camera and it won’t let me drag the target, and the camera pointing straight up (or down.)
No crash happens, but it’s odd, and happens very rarely, maybe once in 3 months…Also, sometimes if in camera view I might click the empty viewport to select nothing, and it moves the camera and or target somehow a bit and I can’t tell how much or in what direction. (It is also not undo-able.)
