I have had a noise porblem when I started to use vray2.0 This problem was not availeble in vray 1.5 is it related with light cache glossy or ?? I am waiting your forward your helps.
Thanks.
Looks more like your subd’s on your lights and possibly the noise threshold may be set too high.
Ofcourse noise threshold 0.005 and vray light subdiv : 25 - 50 I think problem is light cache glossy.But I dont understand when I rendered the same scene in vray 1.5 there wasnt any problem ![]()
i’m getting the same thing here! DMC at 4-50 seems help out, but it’s slooow… so any ideas would be greatly appreciated ![]()
oh, and i have the subd’s on the two lights in my scene up to 512 which helps a bit as well… sigh
Does it go away if you turn off the “Clamp output” option (if you are using it, of course)?
i’ll test it when i get back to the office tomorrow…
have you enabled reflective GI caustics?
maybe it’s because of that…
best regards
themaxxer
Ok then; this is fixed for the next update, in the meantime, you can email me to vlado@chaosgroup.com for the fix or otherwise simply turn off the “clamp output” option.
