Hey Guys,
i have a question. Do you have a lot of more Noise in your Renderings since you use 2.0? And if yes how do you avoid it?
thx for your help
Hey Guys,
thx for your help
Hi ! Is the noise on all image, or more into Dark areas ?
Are you clamped on a pre 2.1 build?
No its all over the Picture. I Use my settings as always but the renderings arent that clear as they where.
My settings
Adaptive DMC 1-16
Exponential Gamma 1
LC/IR 2000/-6-1
DMC Sampler
Adaptive A 0,85
Noise Trsh. 0,005
The best way to solve any noise issue is to isolate the noise and identify where its coming from i.e. is it a reflection noise? gi, lighting etc. Render each of those components one at a time and isolate the issue.
Yes there was a fundamental change from Vray 1.5 to Vray 2.0 and above with regards to the image sampler. I had a huge amount of trouble. This post was instrumental in helping me.
http://www.interstation3d.com/tutorials/vray_dmc_sampler/demistyfing_dmc.html
It is somewhat hard to understand but one thing I did that you are doing also is I had my adaptive sampler setting around .9 and I changed it to .5 and I kept the noise threshold from .005 to .002. In the DMC sampler settings I have it set now for a range of 1-30. The link above does explain (far better than I could) the relationship between the DMC sampler settings and the material subdivision settings.
I hope this helps.
Cheers,
I agree with Morbid, to find the source of noise I suggest using the correct elements (typically reflection, lighting, shadows and specular) and then crack up the right subds
