vray 2.4 license limited to 10 node?
While testing the render farm, I got 16 node working.
After restarting the vray license server trying to solve this other issues(http://forums.chaosgroup.com/showthread.php?78343-Render-host-lbn\*\*\*-(192-168-0-235)-is-not-responding), the render node are now limited to 10.
How can I get back the unlimited render node on the 2.4?
It never was unlimited. You get 10 dr nodes for each vray 2.4 license
unlimited with backburner in 2.4 yes
Thanks, are you sure?
It was running with 15 node in DR mode during the test, until I manually stop/start the license service!
Then I will have to used Backburner if it doesn’t give me trouble with time.
as Morne says, dr it’s always been limited to 10 machines per license. it’s actually weird that you had 15 running, unless you have more than one license..
No only one with 2.4 and the upgrade to 3.
Doesn’t matter for now, I just tried to get the farm up and running for now.
Would it be possible to create a screen-shot of the license-server status page and send it to support@chaosgroup.com along with link to this thread.
Thank you very much in advance.
