Am I right in thinking this feature uses only the CPUs and whatever GPU(s) you have is/are irrelevant?
Thanks,
Thanks,
Only CPU. No GPU.
Use RT GPU.
The production renderer is only CPU, yes. If you want to use GPUs, there is V-Ray RT.
Thanks for the quick replies.
Interesting new feature nonetheless. Maybe even more interesting if Vray supported Xeon Phi… ![]()
We are looking into that, but I can’t promise anything really. V-Ray does run on the Xeon Phi, but it needs more work to be usable. And would it be worth it performance-wise in the end, it’s still unclear, but at least we’ll try ![]()
I’m sure if Phi is any good you’ll find a way of using it. It sounded like it might offer the best of both VRay RT CPU and GPU.
Hopefully it will turn out that way.
