Hi
what do you think?
() Speed up with opacity map is simply amazing! (O__O)
() Random shader very useful!
() I miss very much the nice VRay Hair support.
() VRay VFB so cool.
The framebuffer is simply fantastic.
Ok, that’s some very impressive update overall.
what impressed me is the speed up with Ppacity map!
Normal = 50 sec
Stochastic = 33 sec
Clip = 26 sec
It’s simple amazing. How is it possible!
I remember my old day, fighting with million trees and the “stupid” opacity map!!!
I don’t know, I haven’t had issues with speed with simple cutout maps (leaves) since I did the whole “none” filtering, although it occasionally get stuck when used in more complicated opacity maps for furniture for example.
I am bit wary of new methods since their whole Embree and Probabilistic failure. Embree is unusuable since it disables (without any threshold) every instance, what do I have, 256GB of ram ? It’s usable for those who render boxes.
Probabilistic shaves off time…creates visually wrong look (like most of the time completely different intensity), and introduces new noise.
But these new features do look great. Should have come faster, one year for service pack is bit too long.
Trees are the worst possible scenario of what can happen with opacity maps. It is much easier to find some reserves there, than in clay rendering ![]()
Juraj, I remember some of my old test with VRay (opacity, opacity with filtering off and real 3D model leafs). With opacity map, the trees, obviously, are more light. With real 3D leafs the rendering time with VRay was much better. But, when you have to render a forest, cause out of RAM, I had to use opacity. Same in Corona: 3D leafs are better, because with opacity map, Corona is slower. So, you can understand why I’m so shocked! Now, in VRay, you can use opacity map without problems.
Yes Ondra, I know veeery well. And, if you look my old gallery EXAMPLE (entire forest with trees) you can see how many project I did with VRay.
deleted
Seems to be a nice update!
However this update is acting very weird for me. RT (Both CPU and GPU) won´t work at all, everything is rendering pure black. With some old scenes when rendering through a physical camera everything is black as well haha…
They removed the builds because they didn´t work!
Off-topic, but, best is both 3D geo and opacity ;- ) Opacity is always must, no geometry can create necessary detail. I use 9-12 polies + opacity= best of both worlds. If you create your geometry so that you use only minimum amount of “black space” from opac map, it speeds up greatly, and the rendering difference, isn’t that big at all (30 ~ perc. overhead top).
Lol, what’s up with the black rendererings :- D ? Pops up all over my Facebook feed.
I don´t know, something went terribly wrong so they removed the new builds…
I tried rendering and everything was black and geometry had moved and other stuff…so yeah, will have to wait a bit to try the new version ![]()
sounds like anti-piracy protection backfiring… I know I will be scared shitless when we release Corona ![]()
Every official version you have released so far has worked…so hopefully everything will go fine with the 1.0 release as well… ![]()
That’s the problem with probability luck, he should have had some issue by now to be on the safe side :- )
That´s a valid point :), I did not think of that!
That vray clipper feature is great! Would love to have that in corona - would make doing cutaway arch-viz scenes SO much easier.
I must say, Chaos Group is doing better with this SP1 than I though they would. Looks very nice, and from a totally unbiased point of view.. they are certainly adding a fair few of the features that currently makes Corona much nicer to work with compared to Vray. Interesting.
Edit: But I must say it’s hard to compete with the easy and simplicity of Corona. It just looks good.
Edit2: We have been setting up comparison tests all morning between vray 3 sp1 and corona daily build. And after 2mins of rendering, with the right tweaking (hate tweaking these days) You can probably get more out of Vray in this simple test scene… How ever if you leave both rendering for 10mins, there is no competition. So far I would still pick corona for the type of work we do here.
Did the SP1-update work correctly for you? No black renderings or moved geometry and such? ![]()
Is that a Max-specific issue? The modo version of V-Ray uses Embree by default and that supports instancing. I’ve never used V-Ray in Softimage or Maya.
Sorry, indeed maybe my understanding got mixed in head. It was actually this : I swear I saw different wording elsewhere by Vlado but now I am sorry. Not intended to say bullshit though.
“Currently in V-Ray Embree accelerates only static geometry (as opposed to dynamic, or render-time geometry). To get the maximum performance, it is recommended to set the Default geometry parameter to Static - this will use more memory (any instances will be replicated)”
http://help.chaosgroup.com/vray/help/300R1/render_params_system.htm
It makes my 20-30GB scenes unrenderable or reach far higher.
2015SP2 /3.008 is what I use.
Ah, that makes sense. Sort of.
