vray 3.20.02
good morning. i’ve seen that in vray 3.20.2 the “use dmc sampler threshold” option in not anymore avaiable when i select the adaptive sampler. so i have to manually adjust it to match the dmc sampler. or may i just leave the color threshold at 0,01 and modify just the dmc?
thanks
Yes, it was removed from the UI. Now the user can control the AA quality directly from the Image sampler rollout, without the need to go end adjust the DMC noise threshold parameter. Generally you still be able to set them both to an equal value if you prefer, but most of the users are using the Image sampler settings to tweak the final render quality.
