[VRay 3.4] MaxScript render command not saving images without VFB.
after upgrading to VRay 3.40.01 on our test machine we noticed that our scripts that use the standard Render Output stopped writing images when using the MaxScript ‘render()’ command.
“max quick render” works, but we have a lot of scripts that are using the render command and its arguments, so that’s not really an option for now.
Thanks!
Did you update anything else except V-Ray?
According to my test here this also happens with other render engines like Scanline and MentalRay.
Can you confirm that this only happens with V-Ray into your environment and other engines works fine?
Not sure which arguments you need for the render, but you can easily use Notepad++ and automatically and simultanously select all your scripts and change all references of “render()” to anything else, in this case “max quick render”
