Vray 3.4 Water Material
Did anyone save out the water material for 3.4? When I updated to 3.5 mind disappeared and the water in 3.5 is horrid.. for my uses anyway. Or if anyone has suggestions on how to recreate the water material from 3.4. The first image is 3.4 water, the second is wave water from 3.5 with the refraction removed for the closest visual to 3.4 as I can get. But as you can see it’s no where close and doesn’t look very good.
Probably this will help you: Chaos Docs
No I’m looking for the old material itself. When I go to my old project with the good water the .vrmat that was applied is just gone. It seems to have been deleted with the new version and all the new materials.
Yes, this is because we updated the entire library. The older one is not optimized for 3.50.01. However, you can still use it after an update.
The old library is available for download at the bottom of the page that I sent to you. There you will find the water you are looking for ; )
haha there it is. I missed that, thank you so much.
You are welcome!
