Vray 3.5 gpu and Fstorm gpu 2k scene demo
2k scene
turn hd on please
https://vimeo.com/200589373
I don’t see qny reason why fstorm is better here on the contrary.
Vray uses the gpu in a much more efficient way, and that’s exactly why your system is stuck, because it uses the gpu at its maximum.
Fstorm doesn’t and that’s why you have more smooth windows interactions.
Take a cpu who gas 8 cores. Do one render with the 8 cores on, everything will lag. Start a render and set the affinity to use only 6 cores, well you will be able to surf and listen to spotify. Is that really better? Not in my vision, because your render with 6 cores will take more time.
If you want more interactiveness with vray, lower down the PPP and you will force vray to run slower and you will gain some interactiveness in windows. Again, the same way as fstorm, but for me really, that’s not a feature, it’s just fstorm that can’t utilise the gpu at it’s maximum speed, and I really don’t understand how this can be a good thing for the end user…
What Stanley said.
Also, if you want a fast feedback, we have a settings preset for that. It is called “Active Shade” mode.
Best,
Blago.
p.s. and a nice FAQ here.
If you use the V-Ray GPU in active shade, there is “Low GPU Thread priority option”, OS UI will be much more smooth. Some people want GPUs fully utilized, others don’t. We have presets for both, literally 2 clicks away. If we didn’t people would complain for the opposite.
If you have actual scene where V-Ray GPU renders slow, please send them over and we will fix them. It is hard to debug feelings and testing it here makes me feel pretty confident about how solid the V-Ray GPU performance is, especially 3.5 :).
Best,
Blago.
You can.
So absence of GPU utilization limit in production rendering mode is what’s an issue here.
Or you can change the settings of the production GPU render to not utilize the GPU as much. The defaults are made so it is utilized, since most people want that (they either have smaller GPU for display or render on DR slaves).
If I see any scene that performs significantly slower in V-Ray GPU compared to other GPU renders, then I will definitely send it your way.
Thanks !
Best,
Blago.
I guess we have to do better job explaining that.
Anyway, it is written in this (really) short FAQ here , and is part of almost any GPU guide and tutorial we make. There are links to those in the sticky topic in the RT GPU forum as well.
Best,
Blago.
The GPU thread priority is option from 3.5, which is not yet released officially, therefore it is not in the 3.4 docs.
The tips for the OS UI in the 3.4 FAQ are still valid, of course.
Best,
Blago.
I have not been able to play with beta 2 yet, but so what you are saying Blago, is that you can now have similar interactivity in Vray RT as what Oren showed in the video using Fstorm?
Also with DOF?
guys why the active shade is by default based cpu and not gpu ??? how i can change it to be as default?
Low thread priority guys. And this https://www.youtube.com/watch?v=0CjnkDk481E
I use octane with c4d a lot too, and i believe that RT is better for production. A bit less interactive (though hugely improved in 3.5) but a lot faster than octane, therefore than fstorm too. Try interiors or bright dof/rough highlights an u ll see fstorm bend comparing to RT.
Previewing 80% of the image in seconds and the rest 20 in great time inconsistency is what u get with those engines. RT on the other hand for actual clean image can be really faster than both.
Btw Blago, is there the possibility that switching among gpus and priorities to be done live without reopening RT? Its really convinient this way. Cheers
thanulee, But in your video Low Thread Priority is NOT enabled, and yet the interactivity looks pretty good. The progressive mode and CUDA should be default in active shade, and I think low thread priority too. The goal of Active Shade is to have fast feedback while working anyway.
Regards,
-Eugenio
For Rt what does PPP stand for and why lower it?
It is doable, of course. Just to be sure, can you tell a use case for that ?
Do you mean RPP (Rays Per Pixel) ?
Best,
Blago.
Yes u r right, but he probably uses 1 gpu for the system and 1 for the viewport? in any case low gpu priority means “do not use gpus at 100%” and it must be on when u wanna have interactivity, among other tips u saw in that video. cheers
must be rpp it was in the first solution offered at the beginning of the thread so am here like a mad man looking for it, i did a comparison with a random scene using rt cuda and fstorm, all i did with fstorm was hit convert and changed the exposure which seems to be more of a post thing in fstorm, the noise in fstorm seems to be more acceptable than after 15 mins in vray and seems to keep clearing faster, am no expert in gpus especially with vray so would love to know what to change to speed this up, i used active shade model for vray also because i wanted to compare the interactive modes of each
For example, many times i have a heavy prop that i need to see its full detail to understand whats going on, like bump or sss or glasses, and i want for a moment more gpu power to render faster without re opening the engine. So as i am, i check my other gpu as well, or i change priority and when im done, i just change it again to low and continue working. I dont know if others work like this, but i find it very convinient to boost or release gpu on the fly. Thanks
where is that low priority for gpu RT option?
Its in the beta not on the official release yet. Just in vray RT tab, u cant miss it :slight_smile:
Ah another anti-vray/pro fstorm post from Oren.
Funny, my interpretation was the opposite, that he is doing this because he cares. I would also like to have maximum interactivity when working.
