Vray 3 - Vray toon bug
Using 3Ds Max 2012 and latest Vray 3. When using Vray Toon we have found that we are unable to assign exclude / include objects to the list. Is anyone else having this issue?
Christiaan
Works fine for me on a quick test. If you have a scene that doesn’t work, can you post it here or send to vray@chaosgroup.com ?
Also how are you adding objects to the list? From the UI or from MaxScript?
hmmm i’ve just tried on new scene. it does work, though when i click the “add” button it doesn’t stay highlighted so wasn’t aware that i was able to pick objects… minor
thanks for the quick reply
