Vray 4 beta 1 test render car
A quick test render using Vray 4 beta 1. The CPU render time if I remember clearly was under 1.5 minutes.
The car is looking good!
1.5min for that resolution is very quick! What are your hardware specs?
Thanks man!
Specs -
Motherboard; Z10PE-D16 WS, CPU; Xoan E5-2683 V3, Samsung M.2 for operating system, Samsung EEC ram along with two 1080 Ti
Very nice! Question for you Garth:
I just bought 2 x 1080ti and was wondering if you us one of them for the viewport, or both for vray rt. Is the viewport that bad, that you need to sacrifice one of them? Thanks!
Thank you!
Typically, I use one for the viewport and the other for RT. However, I used both cards for production render. Sometimes I even used both cards when running RT. Keep in mind though that the viewport will lag depending on the file size.
How do I get my hands on Beta 4?
Just log in your profile in chaosgroup.com and you should see it in the download section.
looking great !
I liked the car paint..the only thing that need work is the background as it is too blurry now imo
Si. I didn’t realize that til now. Thanks for pointing that out.
That is the first place I checked, however, I don’t see anything there.
You have to register for it, which I just did.
You may need to send Chaosgroup support team an email for access.
