we still use 3ds max 2019 and only recently upgraded to vray 5. With a dual monitor setup, if you click render in the vfb on the first monitor it will automatically reset every tool detached to the second monitor (command panel, render setup, mat editor, layers…) back to the first one.
I searched the forums, but I haven’t find it reported. Might have missed it though. It’s a very annoying bug and was wondering if there was any workaround, if I’m not the only one having this problem that is…
cheers
m
I am not sure I understand. Could you record a video of the issue happening and attach it here?
I tried to record it, but of course it didn’t happen while I was recording. It seems to be a bit random, and I can’t reproduce it every time I hit render.
Basically what happens is when clicking render, every detached Max’s panel is being rearranged under the vfb.
I’ll try again to get it recorded later on.
cheers
m
