Vray 5.1 Camera tilt shift+IPR issue
There is an issue using the IPR with tilt shift on vray camera. See attached
Same problem here.
Yep, just noticed this as well too.
Try change the Horizontal Shift to 0.00
As I had this issue too in 2019 with VRay Next I tested it now with 2021 and VRay5 Hotfix2. In my configuration automatic and manual vertikal tilt works fine. But when I use shift I have the same problem. If I remember correctly in 2019 it was only the IPR that doesnt match the viewport. But the final render was fine. Now the final render matches the IPR, not the viewport. This is really not usable…
Hi guys, thanks for pointing that out. It’s been reported under VMAX-10803 and our devs will have a look asap. We’ll make sure to keep you updated. For now it appears that stopping and starting again the IPR will match the viewport.
I have got the same problem with vray 5.1 and max 2019/2021. Fov and and shift very different between 3ds max viewport and the IPR window.
Hi again all,
We improved the release thanks to your quick feedback!
You can re-download the new V-Ray 5 Update 1 installations from our Chaos download page now, the IPR issue should be fixed - do share your feedback.
Please accept our apologies for the inconvenience! Many thanks!
It seems to be working fine now. Thanks! :slight_smile:
Yes, the new V-Ray 5, update 1 (5.10.00 build 00003) fixed the issue here
