I used to switch off this filter in the vraydisplacement rollout but now it is not possible to do this. Is it off by default now or is this a bug?
Hi I’m using 3d mapping but I’m sure I remember this option being available previously when using this method. I’m using Vray 5.
Hi you are correct. It was available in V-Ray 4 but since V-Ray 5 it is not. This is done to prevent undesirable results.
So, is this on by default for 3d mapping because I know that it actually created results that I desired when I could turn it off. Some textures required this option?
Hi the filtering has been reworked and optimized. It is always on.
