Vray 5.2 - Clear Previous Render doesn't Work
Hello again,
You brought back this issue that you fixed couple updates ago. Clear previous render doesn’t work again.
Thanks for the update, i guess.
It will be fixed ASAP. Sorry for the inconvenience!
… wondering, how this is possible..? Why take old Code for an Update?
Nobody is taking “old code”. Things don’t work as you think :slight_smile:
… I know…
I just wanted to start a new thread, but my problem seems to be related. I wanted to render part of a simulation by using render masks. But every frame has all of its previous frames in it.
Is this the same issue?
Yes, it’d be one of the side effects.
This is fixed in the stable nightly builds starting with build 31072 (Chaos)
Sorry for the inconvenience.
