been having some issues with vray 5 and running IPR. not even on a complex scene. when i have something selected in the scene it will constantly try to build the light cache. i have to unselect anything. then it will start to build and render. any help?
Maxscript callbacks could also initiate the issue, by flagging a change which the user hasn’t initiated.
F.e., one could have an “when node selected” one, and on selection of any item in the scene a reaction would occur (it could be of any type, really.).
Ensure you have no such thing running in the background (it can be “installed” by scripts.).
I do indeed have a 3d Connexion mouse. However, if I uninstall the software I am no longer able to configure the buttons…
And a colleague of mine also has this problem, although it’s less severe. He doesn’t have a 3d Connexion mouse.
Hello! I figured I’d resurrect this thread for some more information.
I had this same issue in a scene, and it was caused by a VRayBlendMtl using a Distance Texture for the blend map. I first narrowed it down to objects with that blend material, then removed objects from the “VrayDistanceTex” object slots, until there were no objects being used by that map.
Both the Base and Coat materials (only 1 of each being used) worked fine on their own in IPR, and they work fine in their slots as a VrayBlendMtl. But as soon as I added a distance texture to the blend map slot, IPR broke and the Light Cache loop happens.
Using Max 2022, Vray 5.2.1
Just for anyone else strugging to find an answer!
And also, for the Chaos/Vray bug-squashing team: maybe put this on your list of things to look into? Thanks!
Hey @Bowen_Studios Thanks for the feedback
I have been trying to reproduce this for some time now without luck. Would it be possible to share your test scene with us?
I will make sure this behavior is solved
GPU LC has been improved massively in the recent builds, on quality and speed mainly.
