Vray 5 Mat Library
Where should the Vray mat library go for the render slaves. I have installed the VML (Vray Material Library) on the network where all can see it. as well as on each machine. but still having issues with the slaves finding it? When applying textures from the VML in the scene I make sure to pull from the VML from the network location. I have verified that all slaves can see the directory.Any suggestions as to why? Thanks
We only have it on the network. I think the trick we used is to go to the renderslave and in the windows start menu go to vray/chaosgroup and select download library. You get the option to also browse folders and then you select the network folder. This should register the correct location for the slave. I posted it in a thread when it was released so have a search on the forum.
Ha, this just helped me, set the location, and its corrects the back end and now I can see the full library from the network. Thanks
