Vray 5 hotfix 2.
We just updated from next and unfortunately the Ocio config in the framebuffer resets itself after each max reboot. Please see the screenshots below. It’s fine before I save and shutdown max and it defaults back to raw when I restart max and load the scene.
I’ve been completely wrecking my shading for half the day before I noticed something doesn’t add up .
not sure if it helps in any way, but I’m using an aces ocio config setup via environment variable.
Alright! I had to log out, clear the cache and then the vray 5 stable section popped up. I always forget to do that… Thanks vlado! The latest nightly build seems to have indeed fixed it Awesome.
