Vray 5 refractions way to dark
Hello there. I have on big and pretty urgent issue at the moment. My refractions are extremely dark and I can’t figure out why. And oh boy I tried…
Any hint or help is very appreciated.
Thx a heap!
refractions.zip (716 KB)
up refraction max depth in your VRayMtl.
It is at 20 already. Scene is attached as well btw.
It is the falloff map in the ‘Backdrop’ shader…switch off, no problem
Although if just reflection is used then the problem persists…weird…must be a solution…
And there is…just up the max reflection in that shader :slight_smile:
sure but saving to 2021 in 2021 is just way too optimistic.
Thank you very much, yes it was the backdrop shader’s max reflections… damn…
Stuff is easy to miss…glad it’s solved :slight_smile:
