I have two questions.
I am using VRay 5 and want to upgrade to 6 but sometimes I need to use version 5. Can I do that when I upgrade to version 6? Can I use version 5 on the same computer on different 3ds max installation? Of course not both in the same time.
When I upgrade as 3 year subscription and VRay 7 came out in this time, can I automatically use VRay 7 in this subsription?
Thank you.
Our licenses are backwards compatible with the prior two V-Ray versions. You will be able to use V-Ray 5 and 6 on the same machine with different 3ds Max instances. You can open as many V-Ray/3ds Max instances, on the same machine, as you want. Subscription licenses will be automatically compatible with our latest V-Ray version
One more question. Is it planned that VRay 7 will be releases again after two years like all earlier versions? Or will there be some changes in releasing?
Thank you.
For now there is no change in the release schedule.
