Vray 5 version 1.1 Load Errors Sketchup 2021
Hi Everyone,
After updating to the new 1.1 version of Vray 5 for Sketchup i started getting this Load Errors message every time i open an older model. If i open a new sketchup or open models that were done after the vray 5 update it doesn’t happen. Seems like it’s an issue with models that were done in previous versions of vray (not 5). As far as i know it doesn’t affect renders or the UI, but i can update this thread in case we run into some actual issues that would be holding us up.
Error: #<NameError: uninitialized class variable @@shutdown in VRay::AppObserver
Did you mean? shutdown?>
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/observers/app_observer:69:in `shutdown?’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/helpers/throttle:14:in `block in handle’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/sketchup_entitlements:40:in `is_online’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/sketchup_entitlements:40:in `module:SketchupEntitlements’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/sketchup_entitlements:5:in `module:VRay’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/sketchup_entitlements:3:in `<top (required)>’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:59:in `eval’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:59:in `require_crypt’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:59:in `<top (required)>’
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `require’
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `load’
C:/ProgramData/SketchUp/SketchUp 2021/SketchUp/Plugins/vfs.rb:29:in `register_extension’
C:/ProgramData/SketchUp/SketchUp 2021/SketchUp/Plugins/vfs.rb:29:in `module:VRay’
C:/ProgramData/SketchUp/SketchUp 2021/SketchUp/Plugins/vfs.rb:4:in `<top (required)>’
Thanks,
Levente
Hi @levente_redecky
Would it be possible to forward such sample project to see if we can reproduce the issue here - use the Pack Project tool from Extensions > V-Ray > Pack Project. Best would be to reach us through our contact form, just make sure to mention this thread in the email.
