Updated to version 52004 today and instantly noticed 2 issues, First one as per the attachment image.
The second involves the material defuse texture preview window. It displays black screen on GPU preview render but the correct material bitmap when set to CPU for preview rendering !?!?
Windows 10 latest build etc.
X570 / 5950X / RTX3090 (on latest studio driver)
The second issue you are describing is a bug and our team is working on a fix(WEBUI-6134)
Regarding the first issue, can you please log in a request below?
https://support.chaos.com/hc/en-us/requests/new
Thanks, by log a request are there any files you want as I just get a form to fill in and I guess, regurgitate what I’ve posted here again ?
Hi jason_cafferty,
Please note that if you have downloaded the library already, you can just uncheck the updates option and then click Continue.
This will let you use the library until we figure out what has caused the problem.
Konstantin
