Very excited to see that ocean support has been added to VRay 6.
I am trying to get it working. I followed the video as close as possible, but it just doesn’t seem to render any displacement.
I have attached my hip file. It would be great if someone could point out what I have done wrong
spectra_test.zip (330 KB)
Hey @Dubbie99 ,
When dealing with live meshes, they need to be packed prior to assigning a displacement material - that’s not just for the spectra but displacement in general.
Simply add a Pack SOP in the chain before the Material SOP and you should be good to go.
Best regards!
I still can’t seem to get it to render the ocean. It would be super helpful if you could provide a scene that works so I can look at it.
if I set the displ amount to 0.9 instead if 1, it now renders - however the scale seems completely off.
Here is the ocean preview which looks correct
Here is the render
Hey @Dubbie99 ,
I’ll double check with your scene over the weekend. I forgot to mention it in my previous post - there’s an example page in our documentation that shows some demo setups here: V-Ray for Houdini
It might be helpful to check out although the setup is fairly straightforward so it’s possible you’ve hit an issue. I’ll get back to you when I know more.
Best regards!
I found the sample scene and it worked. Still not sure why my original scene doesn’t work, I think it is set up the same.
thanks for the help
