I’ve been using vray for many years now, but it’s the first version that makes the entire system laggy. So laggy that the PC is pretty much inoperable. Some time it doesn’t even recongize if I press stop rendering or press esc. And forget about using the computer for anything else while rendering. Not even writing an email. Feels like vray is using 99.99% of the system ressources.
Yes, it happens to me too, not so exaggerated, but the same thing happens to me… I thought it was because I used Windows Professional instead of the home version.
i have 64gb ram and intel i9 7940X with 24 threads!!
Indeed, the goal is to utilize 100% of the resources, after all. It can make some actions like passing a ‘stop’ (escape) command lag, that’s true.
If you plan on doing other tasks with your machine, you might want to consider enabling “low priority” for V-Ray.
For V-Ray, it’s under Render Settings > Settings > System > System - advanced.
You can use the same place to lower the number of CPU threads used for rendering, so 1 thread is left for other tasks.
For V-Ray GPU, in V-Ray 6 you can assign low priority for each rendering device under the new Device Selection options (Render Settings > V-Ray tab > V-Ray render devices selection).
So much that I can’t even press the “stop render” button? Because that is how it is now. I often have shut down Maya via task manager to stop a render because I can’t do it via VFB. I understand that we want to use as much render power as possible, but this has never been an issue before. What has changed?
If that’s the case, then a good practice is to not let V-Ray (or any renderer for what matters) use all your machine cores. If you have 64 cores, for example, try to set your “Max render threads” to 56 (default is 0, which means V-Ray will try to utilize all the threads available, leaving your Windows system without resources).
This, along with “Low thread priority” (only if the first method doesn’t fix the issue completely) should do the trick.
I’m glad somebody is backing me up on this issue. It shouldn’t be required to do Ctrl+Alt+Del to stop a render prematurely. And it was never an issue before.
Maybe “Low thread priority” should be enabled by default. I forgot to set this in a scene and I was not able to cancel a render. No amount of hitting escape worked, and even the Task Manager was not responsive enough to let me kill Maya. I ended up just doing a hard reset so I could have my machine back. That should not be necessary.
I had to revert back to Vray 5 today for this exact issue. I also think it may be specific to Maya for some reason. I am also working with Vray in Rhino with Vray 6 and the issue is not there at all. My main issue came in the framebuffer. I was finding that I couldn’t zoom, edit exposure, etc, without the system lagging bigtime. In the framebuffer in Rhino, it works perfectly. No lag, system is smooth and fast. So why the issue with Maya? I did a complete reinstall today and the problem persists.
I would not agree that killing renders has “never been a problem before” with Vray, but in any case setting a thread limit and using less than 100 percent of available RAM for renders should be all that you need to do. This is rendering 101.
