Hello.
Can i install vray 64bits on a workstation and install vray 32bits on rendernodes with the same license?
and if yes, can i render the same scene at the same time on 64bits and 32bits rendernodes?
Thanks for your help
Hello.
The license does not make a difference between 32- and 64-bit nodes; for DR you can mix 32- and 64-bit, although this is not recommended. You can also do that for backburner rendering.
Thanks alot, i have 5 rendernodes with win xp pro 32 bits, but there isnt an upgrade to xp 64, only a new license to much for 1 more year of use. then im planning to buy a new workstation but 64 bits an still use the render nodes, Mainly for use with the backburner for animation, there are some bug known in this case?
Thanks!!
