vray 7.3 problems
1. The Livelink between the latest vray 7.3 DR2 to Vantage isn’t working at all.
2. The Livelink in non-DR2 version DOES work, however setting the Max’s viewport to a Vray camera (during Livelink) makes Max 2025 crash to desktop.
1. Works fine on my end. Are you using the latest Vantage (3.2.0) release? Also, ensure that the Port number in 3ds Max (Vantage Live-link settings button) matches the one in Vantage (Live-link > Change port…). It should be 20703.
2. This is a known one and is fixed in our internal builds. It should go to the stable builds soon enough.
After changing to 20703, I’ve got Livelink working with DR2 version. And, as a pleasant bonus, no more vray camera crashes in a primitive teapot scene so far.
Thank you!
Hi @juliaav , could you provide more information on how to reproduce 1. ? I managed to reproduce 2. and we’ll be looking into it, but DR2 Live link seems to work as expected.
Simeon
@s.balabanov To reproduce 1.. please install DR2 vray 7.3 and make sure port 20701 is being used. Livelink won’t start
Now, if DR2 becomes a new golden standard, maybe port 20703 should become the default one?
Edit: please install DR2 vray 7.3
I see and it makes sense - as you stated, DR2 listens on port 20703 and it is important to have it properly set. We did change this in the configuration files, so I guess it was some issue with the installation in your case that prevented changing the port during installation. Happy to see you solved it and you can continue working with Vantage in Live link!
Simeon
