I must have missed something, but none of the color management works with vray with maya 2026 and vray 7. What is the solution? Everything renders the wrong colors, file texture color spaces are no longer respected, which worked fine in vray 6.2. Can someone please help. I have OCIO system env var set. I have a Maya_OCIO_CONFIG var set in maya.env. Maya does not let me specify my OCIO config.ocio file, so the only color space that works is sRGB. Desperate here, may need to abandon vray 7 if this is impossible to remedy
Seems ok here in 2026, but I just use the default prefs location “<MAYA_RESOURCES>/OCIO-configs/Maya2022-default/config.ocio”
if I load a file texture that is anything other than sRGB, it does not render correctly. This is reproducible across all computer in the studio, windows or Linux.
OCIO system env var is set
Vray 7 does not seem to know what “scene-linear rec 709/sRGB” is at all
vray 6.2 on maya 2026 has no issues
I did some digging and it appears running these commands (MEL) fixed the issue:
colorManagementPrefs -e -configFilePath "<PATH>/config.ocio";
optionVar -sv "colorManagementConfigFilePath" "<PATH>/config.ocio";"
Also, it turned out there was this running in a scriptNode that was probably causing issues:
colorManagementPrefs -edit -cmConfigFileEnabled 0 ;
Why Autodesk decided to roll their own color profiles that are different from industry OCIO, I’ll never understand
