Hi guys.
Im in need of some help.
Im trying to render an animated scene in a mud/dusty forest using chaos scatter for trees.
My probelm is no matter how high I place samples, 10k in this instance and drop the Noise limit to 0.005 I cannot clear the noise. Its outside of the denoising areas so it means I can’t up the noise to get quicker renders and reply on denoiser to save the day 90%.
I have tried 2 versions.
V1
An early version using GPU and around 5minutes a frames but that cause noise. The noise looked like the “locked noise pattern” wasnt working. With dropping the NL and upping the samples this took crazy amounts of time and still didnt clear anything up.
(GPU Progressive render, CUDA & CUP C++ hybrid)
V2
The lastest version I have got set up using these setting and things are better but im used to clean renders with denoiser.
(V2 samples in screen shot GPU bucket CUDA & CUP C++ hybrid)
If you cycle back and forth with the frames you can see the issues.
The aim is to get cleaner renders so my eye isnt drawn to the noise. V2 is better but I still think It could be cleaner, and faster. If I want a full HD frame then its also longer.
I spent all weekend testing all combinations of samples limits and noise limits, using the sample rate RE to test and improve. Even switching back to cpu which also took longer and still kept the noise at a level undisrable.
Its leading me to think there is a bug maybe. I have never rendered 10K plus samples without being able to up the NL to speed things up so im a bit stumped.
Strangley I found the GPU bucket to be quickest at Hyrbid mode
Specs
Ryzen 7950x
Nvidia GPU 3080 on 572.16.
Latest version of 3Ds and Vray
BTW new Studio drivers sends CPU temps up and cause bluescreens, tested on 2 machines now, 1 had to go back in for warrenty repairs. No idea whats happening there but 572.16 is stable.
I can send you my scene if you have time to look. It contains both v1 and v2 scene models
Hope you can help.
Kevin
V1.zip (2.36 MB)
V2.zip (2.02 MB)
