Maybe something obvious but i can see to find an answer.
I’m trying to light an object with a transparent alpha.
In the VFB 2 , i’m putting an image in the “Background” folder.
I have several colors correction layer affecting my render BUT it is also affecting my background image which i do not want as the background image have correct colors.
How to not be affected by that ?
Use an image alpha mask in the layer affecting only the render, it will limit the effect of those corrector to the non-transparent part of the image and therefore discard the background.
If you have few, you can even move the correctors affecting only the render in a separate folder and apply the image alpha mask to the folder itself so whatever you put into this folder will only affect the non-transparent pixels.
Indeed, it is a way of doing it.
Thank you
