VRay 7 Render Vars Bug with Animation Render
We switched one of our scene from VRay 6 to 7. But it wonly just renders one frame and then stops rendering.
The only fix I’ve found is by removing the renderproducts in the render settings, but that also disables vray render vers which we need.
ANy idea on why? Might be a new way of setting the render vars that we do not know yet. We’re in Houdini 20.5.487.
Thank you!
Hi @andrew_cyrmarcoux We are currently discussing the matter and I will come back to you via ticket 378055. Thank you for your patience!
