Vray 7 update 2 hotfix 3
after updated, i click vraybitmap view button it show this message in image vray-issue-000.jpg, I click ok, it show the texture and show message in vray-issue-000-01.jpg
Is it a .tx file?
EDIT: I saw the other screenshot. I’ll log the issue. Logged as (internal tracker ID: VMAX-15362).
On my end, the window opens (with the correct image) after I close the error message. Not sure how you get another image. Otherwise, that Render Window message is from the Autodesk log; uncheck the “open on error” option to remove the annoyance.
yes, it is .tx file.
for your info the image is correct. this 2 difference screenshot.
I was about to update, is this a ‘game’-breaking bug?
Not really.
Ok thx. I saw you guys fixed cryptomatte (xref objects - multimatte) and the import (units) issues with edgestex / dirt maps. Can’t wait to try! Big thank you! I know I was bugging you guys a lot with it :-).
We fixed it. Download the new build from here.
do you mean yu have fix the bitmap issue?
PS: I have download the new build, thank you.
Hi, Yes, the new build fixed the issue, thank you.
