Hi
I just Installed Vray_adv_43000 trial (30 days), no problem with the environment variables:
VRAY_FOR_NUKE_12_1_PLUGINS = C:\Vray_Nuke\nuke_vray
VRAY_RT_GPU_LIBRARY_PATH = C:\Vray_Nuke\vray_std
NUKE_PATH = C:\Vray_Nuke\nuke_plugins
PATH = C:\Vray_Nuke\nuke_root
loaded the script you provided (quickStart_01_intro_end.nk) from qs1assets to test how it work but unfortunately when switching to VRayRenderer, nothing is rendered in viewport and all RenderElements are black!
any solutions for this?
Edit: I tested with a simple sphere and same thing, I get black render !
As you seem to be using a zip installation, you did not go though the automated installation. Did you properly installed/setup the licensing access ?
The first thing to check would be the log file which by default is saved in %TEMP%/vray4nuke_log.txt - if there is a licensing or installation issue, there should be some clear warning there.
no error in log file, and yes I properly installed/setup the licensing access (when Installed Vray for Houdini)
reinstalling Vray for Houdini fix the issue for vray for Nuke,
All work fine!
thanks
