vray adv bitmap converter
hi guys, the convertion of vray bitmap don’t works properly.
Lights, materials an camera is ok …
ohter thing that is not converting correctly is the vray 2 sided shader
  1. 2 sided shader was slightly fixed. In next daily build it will be better.
  2. About others. To improve conversion I need more “real” examples (better scene, images will not help). So, if you found something incorrect, please send the small example scene, this will be very appreciated.
