Vray and Bongo
Since vray fails to automatically save rendering - Vray stops rendering after first frame when I use Bongo. (I have checked batch rendering)
What could be the problem here?
The two did work fine together on my old system, but with the newest SRs on all programs they are no longer friends?
Is there a setting to make Vray save automatic, or is it so that Vray no longer works with Bongo?
Please reply if you know, I have been trying for quite some time to make it work now..
Re: Vray and Bongo
OK, I will answer to my own post here..
Vray can not save files to folders or filenames with åäö. ..Very simple problem it seems now.
Re: Vray and Bongo
I’m having the same problem with VRay & Bongo. After rendering the first scene with Vray it stops and doesn’t
continue with the rest of the animation.
I tried using very simple files names etc but it still stops after the first render?
Is there a setting that enables VRay to render more than one at a time? Feel like I’m missing something here…
Re: Vray and Bongo
Did you enable batch render at the global switches?
Re: Vray and Bongo
Great, you’re a gem thanks. I’m still getting the hang of the software!
