yeah aside from the floor reflection it looks very similar.
How about times? I found V-Ray to be much faster.
Well, they all rendered with progressive rendering for the same amount of time. But you can see that the V-Ray ones came out cleaner.
yes the vray ones are coming out faster with progressive and very similar to the corona images as well, what version of corona are you using?
The latest demo on their website; 1.3 I think?
ahh, i was using the 1.4 version with the new adaptive settings and the integrated denoising levels, well i am turning denoising off
When they release 1.4, I will have to redo the tests, I guess. Btw I turned off adaptive sampling in V-Ray too for this test. In any case, you asked about lighting distribution and GI, so adaptive sampling won’t really change that (it should only affect noise levels).
kool, the 1.4 versions have been out for some time now, but the latest build gave me some FTH errors and all my max files ended up corrupt so had to switch to vray for the interiors and redo the work so i guess they have issues over there now so its why its good to have both:)
I don’t see a point of having both unless you have to interact with others that use Corona or VRay? I mean, if they both do the same? Not sure, what are the advantages of having both other than being able to exchange files? By the way, now that I have your attention, does anyone have or know a script that would change Corona files into VRay? Just like the guy from Corona that came up with the material/lights converter from VRay into Corona? I happen to every now and again get files in Corona and have to change their materials and lighting.
The regular V-Ray scene converter has some functionality to convert Corona stuff to V-Ray, but it may not work for the latest versions of Corona; we will need to update it.
one big benefit so far to using corona until now for me was the denoiser which came out and render times and the way the lights looked inside interiors, you did very little and things just looked realistic out of the box, idk its hard to explain until you try it, before the last few months it wasn’t really usable because you needed to waite forever for renders to clear up but since 1.4 version its really fast and at the end the denoising was just amazing, on some massive scenes i could stop a render at say 15 mins and have something very usable to look at. but now vray will soon have a denoiser then i guess competition is heating up which is good for everyone but there is no reason why anyone wouldn’t have both, they are both fantastic and i bet one way or the other you will have to come across assets or scenes you will need to handle in both renderers and you will then need to know both but a vray user can easily learn corona, there is nothing to it only a corona user will have a little learning curve by trying to learn vray…plus in corona there are no splotches, man i hate them in vray, in vray you have to turn up settings to get rid of those babies in corona just render away so there are some benefits in my book, but personally i wont care so much once the denoiser is out, less render time and faster images
It’s only because you, like so many older V-Ray users, stick to the irradiance map and stubbornly refuse to just use the default BF+LC settings ![]()
us cranky old farts. (seriously though i love Imap, but i must admit im using it *much* less these days. not on stills for about 6 months.. … still the only choice for the caching and multiframe incremental though..)
having said that, when i do use imap, i cecrtainly dont complain about the blotchies though. i adjust to remove them, or switch to BF.. theres always a price to cutting corners eh?
Hah! We have this same thing happen in house. I’ve switched to BF (and LOVE IT) for easily the past 12 months if not more, and our other 3D guy still uses IRMap and still complains about splotches. Needless to say I have told him countless times to switch.
What I generally love about VRay is how you can totally bend/brutally f*** up/massacre the **** out of it in every way so you get a desired result. Want it physically correct? No Problem, out of the box. Want to fake ****? No problem you can nearly always adjust everything to your liking. Very flexible.
issue i have with BF and LC is time, it takes forever on my machine and IR map is so fast in comparison, as soon as denoise is there am down for BF but for now, not touching it with a ten foot pole
It’s not really a bug; that’s how the “fix dark glossy edges” option works. I can’t really change that easily. A work-around is to use a different BRDF.
I am sorry lots of you guys have broken version that is slow, produces splotches along with different kind of problems.
I guess i somehow got fully working version of vray. Who knew i am so lucky, i could have end up with broken version just like you guys.
