Vray and hyperthreading???
hi guys,
i have a new computer (mac pro) which i am running in 64-bit vista using bootcamp. It has 8-cores that also support hyper-threading. I am definitely not an expert when it comes to these things so please correct me if im wrong, but in many other applications it shows that i have 16 cores all of which are running at 2.4Ghz. Can vray use hyperthreading as this would obviously reduce render times hugely in complex renders.
thanks for your help :slight_smile:
Re: Vray and hyperthreading???
If you have one core without HT running 100%, or one core with HT where each thread runs 100% - surely that is the same speed then?
Or are you seeing that of the 16 threads on your 8 HT cores, only 8 are working?
And I’m a but unsure about how HT cores work, if you have an HT core and one of the threads use 100%, does that mean the core works only 50%? Or might it not be so simple?
this is what i am unsure about. Although when i render a scene it says “setting up 8 threads”. Should this say 16 or will it make no difference at all?
Thanks for the reply
Have you looked at the performance tab in TaskManager while it renders?
Jarrod, you have to make sure your scene is set up to use all 16 cores.
Check your “passes” option under Light Cache tab, is this set to 16 not 8?
Regardless, IR and DMC should produce 16 buckets.
I am pretty sure that the buckets work off of how many cores there are, regardless of hyper-threading. Most computers these days have either hyper-threading or hyper-transport, and I don’t think I’ve ever seen a dual core machine pop 4 buckets up during a render.
I have some render slaves at work, old P4, single core. But some have HT enabled and it brings up 2 buckets for them
I had a look for the passes setting, but could only find “Num Phases” in light cache? not sure if this is what you meant, but changing it had no effect.
Also i went through a few programs to see what they said about my computer including the windows info menu and here is what they show:
i am unsure if this is normal, however in the system properties menu above (and in speccy) it does not show at all that there is even a second core (maybe this is just because it only gives info for the first?)
When looking in device manger though, it does show 16:
Is it at all possible that this is an OS thing? (particularly because i am using a mac processor in win?)
thanks for all your help :slight_smile:
I’m on a macbook, and I get one bucket per core. I’ve never seen hyperthreading yield more buckets, but then again, maybe we’ve been doing it wrong all along…
oh, another good point, if your cpu is being used 100%, who cares how many buckets there are. The cpu is being fully utilized during the render anyway.
The new works laptop is a hyperthreaded i7 Quad@2ghz = 8 buckets
Other platform is a 3 year old desktop with Q6600. . . non-Hyperthreaded Quad@2.4Ghz = 4 Buckets
Which one is the quickest? . . . The Q6600 by a mile.
yeah i guess this makes sense. What is the difference whether i have one core working on one render or one working on two, it will still take the same amount of time.
I am guessing that hyper-threading works well where you have two relatively small tasks that can be completed by one core, eg one that takes up 25% and another that uses 60%, but does not mean that the core can effectively “duplicate” its work at 100%. It is probably more efficient to have it dedicated to one task.
makes a lot more sense now
thanks for all of your help, really appreciate it :slight_smile:
