These are file paths and require string as input. Here is one example: renderers.current.adv_irradmap_autoSaveFileName=“c:\test.vrmap”
#output_splitbitmap
I’m not sure about this one. Have to check with our developers.
#includeListOverrideMtl, \ #excludeListOverrideMtl, #excludeListRenderSubset, #includeListRenderSubset
The include/exclude lists can be filled up by adding objects or current selection. Example below:
renderers.current.excludeListOverrideMtl=$
$Sphere:Sphere003 @ [-28.559904,14.545385,0.000000]
#($Sphere:Sphere003 @ [-28.559904,14.545385,0.000000])
Thank you.
I kind of know what these properties are doing, I am wondering how to deal with them.
for most nodes in 3dsmax I can do this:
props = for i in (getPropNames node) collect (getProperty node i)
for i = 1 to props.count do setProperty node (getPropNames node) props
if I do that with the aforementioned properties it triggers very bad errors, with messages I have never seen like C++ shits.
The purpose was to copy/paste VRay settings
But nevermind I am kind of giving up on that and copying renderers.current as a maxObject…
My next question is how do you test if VRay VFB is opened or not?
Currently there is no maxscript command for that but we’ve added a feature request about it, it will be available under vfbControl() command once ready.
Thank you
Since 3.5 I actually don’t need to close the VFB when setting render.current to a new instance of VRay… it used to keep the old VFB and open a new one which was annoying.
Now it seems to work fine.
