vray and shag fur
lil test render using shag:fur, simcloth, and vray
still frame:
3 second anim:
http://myweb.cableone.net/amylenhart/stuff/feather2.avi
vray and simcloth is cool
Crap! What was the render time?
about 30 secs a frame
Percy,
Are those opacity mapped shag hair?
Funny!, cool test.
More of that please..
gr,
Leon
So for what did you used Simcloth?
By the way looks extremly cool. Only the collision between some feathers don’t work good. The Dynamics are Shag? That would explain much. Maybe you could share the scene, or discripe what you did, because I do a lot of Shag-Vray test at the moment too.
robert
there is no opacity to the feathers. The dyanamics are simcloth. Yeah there is some collision but it was a pretty quick setup and first test render. I posted it cause I thought it turned out so good for a first time.
http://myweb.cableone.net/amylenhart/stuff/featherstest.zip
needs shag:fur, simcloth 2.5 and vray advanced
just hit start calculation and itll look like the anim
percy
Now I understand, but I have some problems here.
1.) The Hair don’t render with Version 15. (I had to install a newer Version.)
2.) It doesn’t work with SimCloth 3 (I installed simcloth 2.5 again)
SimCloth is way better in Dynamics then Shag, but 2.5 is so slow…
robert
ok so other than your lack of patience :wink: what is the problem?
Well I do not have a problem, but I had. Beside this I have done a small bird animation, but I don’t think Dynamics are so good. So I will wait till simcloth 3 is supported..
robert
