VRay and Smedge
does anyone have experience with Vray for Maya and Smedge as Render manager?
I have a small 3 CPU netrender Farm(Windows 7), and i´m using Smedge 2011, the network is correct, because all renderings with MentalRay work, but if I netrender Vray for Maya from smedge, I get “Could not obtain a license(0)” as an error message.
My Distributed Rendering in Maya with VRay works well, so I´m wondering about that, because the license check should work as I see by the working Distributed Rendering function.
I know the Error message is one from Vray, so, do I have to check some license path somewhere in the system or something like that?
The Clients have the right path to the server CPU, I checked that in the server settings…
Also disabled firewall, but no success…
Maybe someone knows that problem…
Thanks for your help,
all the best,
beatmanb
Found the solution, one of the license settings was wrong, Vray put a // in front of it, don´t know why, but without that it works great!
greetz,
beatmanb
Ok then, good to know :slight_smile:
