can’t get the license to work on vray64. I have it working on my 1.5 for 32 bit, but do I need a new license for it. the interface looks different.
I had it working there for a bit when I directed it to the license server, but then after using the 32 bit version for a day I go to vray64 on my rel9 of max and boom it aint working, can’t get the license.
When you installed it in max 9 did you chose the software license method? You might also try the IP instead of the computer name or visa versa depending on which you tried first.
For Win64, you *must* have the license server application working, even if your license is on the same machine. This is not the case on Win32, where V-Ray will still find the local license even if the license server is not running.
thanks it’s working now, butI have swithced back to MAX 8 and vray for 32bit because it was crahsing too much. too many deadlines can’t wait & spend too much time figuring it all out.
