Vray doesn’t seem to be ignoring the vray clipper when rendering atmosphere or alpha channels.
Seems to be working fine on a simple test, is it possible to provide a simplified version and share the expected results? Thanks!
Here is a link to the file. Check out the vrayAtmosphere element and alpha.
https://drive.google.com/file/d/1IQ3…ew?usp=sharing
Hi @justini ,
Thanks for providing a scene. If you select and right-click on the clipper object > Object Properties and disable ‘Apply Atmospherics’, it should render as expected and not appear in those passes.
