I’m trying to add the env VRAY_AUTH_CLIENT_FILE_PATH to my Maya launch script but I can’t find the “vrlclient.xml” file on Linux. I’ve searched the various Vray and Maya directories.
Where does this file live? Is it generated by the rpm install? What does a sample vrlclient.xml look like?
I’m assuming this is an important env to set, correct?
Thanks!
You can find it in the ~/.ChaosGroup/ directory.
The file is generated by the tool setvrlservice.exe (it is in the vray/bin directory).
I think there is some information how to use it in the install document comming with the installation.
/Teodor
Thanks! Found it.
The install docs do mention the file, but they don’t state where it lives, but it should!
Appreciate the help,
Rich
