Hi All,
EDIT: Fixed - The issue was related to a bluetooth mouse. After an afternoon trouble shooting various suggestions online the fix that worked for me was to remove the dongle and put it in a different USB port
I have a weird issue happening over the past few days working on Sketchup Pro 2021 on Vray V5. I updated to V5.1 and it still occurs. I have tested it on legacy SU models as well as my current project and the issue is the same.
When I attempt to use ordinary render, or use interactive render, in either standard or spherical panorama mode, the Frame Buffer zooms in to 102400%, I can zoom out using my mouse or double-clicking but it zooms back in again. It is the same whether the render is complete or in progress.
I have also noticed that when accessing dropdown menus, say when switching between standard and spherical renders the popup just flashes on the screen rather than staying.
Apart from this everything else appears normal and I don’t see others reporting this issue so I suspect it is local to my machine or setup. Has anyone experienced this or any idea why this is happening?
Win10 pro, Ryzen 9 3900x, Nvidia 2070 RTX.
Thanks for any insight
Paul
